Best place to add tee for boost gauge
Skylar Hale
I am finally getting around to adding my vacuum line for my AEM failsafe gauge to display my boost. Where would be the best place to tee into to run the vacuum line to? Would the BOV line be fine :?:
Yep, that is where mine is. Between the IM and BOV.
xxBLOOD88SHOTxx
Surge Master
Straight off the intake manifold is where I would do it, it's going to give the best and most precise reading.
TokyoSkies
Boost Junkie
This, but most readily accessible vacuum sources will give you a good reading. I tee'd off of my intake manifold's vacuum line, and it gave me a very concise reading (using an analogue Autometer gauge).
xxBLOOD88SHOTxx
Surge Master
True, it will tell you the right number. I just go as close the source as possible, the closer you are to the source the faster and more accurate it will be no matter what. But again, it will work off the BOV.
