razrbullet
I have a 2000 Honda Civic DX 4dr and wanted to know how to convert the rear drums to rear disc brake. Can anyone give me an exact list of parts I will need to complete this project?
I only ask how to convert it. Plus its way easier to replace brake pads than brake shoes, TWO They out perform brake shoes, THREE they look good overall. Why do you think all the new cars and sports car have rear disc brakes, better braking power.Do you want rear disc believing you will gain braking power? Or do you want it merely for looks?
The majority of braking power comes from the front. If you want more braking power, you're better off getting new rotors and pads that bite harder than your standard Advanced Auto pads.
I disagree. The Nissan Cube, Honda Fit and the Chevy Cobalt have drum brakes. I know there's more too.I only ask to convert it. One its way easier to replace brake pads than brake shoes, TWO They out perform brake shoes, THREE they look good overall. Why do you think all the new cars and sports car have disc brakes in the back, better braking power.
ek forever guy already responded as to what you need. It's not hard unless you run into frozen bolts and/or don't know how to bleed brakes. I agree. Rotors look better than drums and obviously provide more braking power. But not all new cars, or trucks and SUV's for that matter, come with 4-wheel disc brakes.I only ask to convert it. One its way easier to replace brake pads than brake shoes, TWO They out perform brake shoes, THREE they look good overall. Why do you think all the new cars and sports car have disc brakes in the back, better braking power.
Thanks for the advice and help. I'll look up the parts and cost an save for them...You need the full rear trailing arm assembly from a 94-01 integra or a 99-00 civic si.
You need emergency brake cables from a 99-00 Si as well, or you can make the integra ones fit. I did, and it was a major pain in the ass.
It's overall an easy swap. The biggest pain was routing the ebrake cables. Keep the toe arm from your civic. Do not mess with the adjustable side and you can leave your alignment alone.
Edit: As the above poster stated, you really won't benefit from the performance upgrade unless you're autocrossing or doing track days.
There is very minimal benefit other than aesthetics.
The proportioning valve on all 96-00 civics are identical. There is no need to swap them.I personally did this swap myself and it was easy just time consuming. My only question that i have to other people who have done this is that, did anyone of you use or need the proportioning valve from an EM1?
thats if you leave that piece attached....i dont see how you could get it apart while its on tbhYou don't need to align your car if you leave the toe compensator arm alone. Leave the civic one on and ditch the integra/EM1 piece. It's kind of a pain to install it that way but it saves you an alignment.
I had no trouble. Swapping the trailing arms was a joke, minus routing the cable and getting the integra lines to fit the civic route, they are a hair too short.thats if you leave that piece attached....i dont see how you could get it apart while its on tbh
