no dash lights
Status
Not open for further replies.
Kensai
Fuse
Deezy
silent partner
I would start by checking fuse #15 and # 19 with a test light/multi-meter.....And:welcome: to the site....
98civb18c
Dimmer Switch. 99% sure this is your problem.
98civb18c
Guy I had this same problem with my Si. I couldnt figure out what it was for the life of me, then RonJ came along and said it was my Dimmer Switch, which it was. Hella Simple, Quick Fix. Just passing along the word of wisdom.
Deezy
silent partner
Fuse # 2 is not used, and # 17 is for daytime running lights in Canada...Most likely it's your dimmer switch....
purpej1
honda fiend
do the dimmer bypass i think its a red wire and red/blk or gray wire and black wire cut the red from behind the connector and tap it into the black wire cluster should light up
gerardd
Thanks Ron..have had my 95 honda civic now
for 2 days and you already helped me 4 times..i have same issue and was my dimmer switch too ;-)
jumped red to black on dimmer and BAMM DASH LIGHTS!
PricetonB
had this same problem and tried to bypass red to black. It caused a spark followed by the headlights no longer working unless brights are on. please help.
Status
