'00 Civic B18B1 swap, brake issue
rkouns51
I have a 00 civic cx I did a b18b1 swap and then all of a sudden I can't build up break pressure I replaced the master cylinder and wheel cylinders on the back and I still can't keep pressure any help would be great
rich_rolla
Can u tell me everything you had to do to do the swap I have a b18a1 I want to put in my 97...
When u bleed the brakes does it have any pressure or squirt any brake fluid out of the bleeder valve after u pump them up a little bit
Mr.Baker
Mr. Search
The real question is, DID they bleed the brakes to begin with?
HeX
Authoritah, respected.
Its brakes and not "breaks" which is too short of a title anyways, so Ill tweek it for you.
Whether or not youve done so yet, make sure you bleed the brakes at each wheel. If you didnt do so before then thats likely the culprit to your issue.
rkouns51
Try I work for a living.. I used a hydro clutch and bled the lines found the problem Wich was a bad booster why would I use a cable clutch in a hydro car?? And as far as the swap I converted a auto car to a manual car also had to change motor mounts t bracket wiring harness to a si harness had to use si post mount jumper harness to keep obd1
Mr.Baker
Mr. Search
1.What does your clutch have to do with your brakes?
2. Nobody said anything about which type of clutch actuation you used.
A post was there but I deleted it. My fault. I deleted an off topic post from another user, "He probably put a cable clutch in changed the master cylinder and never bleed the brakes haha"
