'00 EX wont start after changing parts
henryfigueroa198
I change the distributor the starter the crank shaft sensor the fuel relay on my 2000 honda civic ex it cranks but won't start
Sent from my LGL21G using Tapatalk
HeX
Authoritah, respected.
As specific as "car problem" is compared to all our other titles, Im changing yours to something relevant to your issue. Please do so in your future posts.
You also created 3 threads about the same topic within 20 minutes of each. That time could have been spent writing a clear and detailed first post with proper punctuations, and posting this in the correct section (which I also corrected). Exercise patience and do not annoy the forum in the hopes of a quicker response as that behavior will only work against you. It is Friday evening and people have lives & families.
HeX
What prompted you to change all that? Did you have any engine codes? Are you sure the distributor rotor isnt loose & the harness is plugged in?
mc360
boosted hx
Most likely put the distributor back in 180 degrees out of time or you didn't mark your distributor when removed and now it's out of time.
