Anyone know who can fix my 02 censor? I got a 98 honda civic. I recently ( 3 or 4 months ago ) added my headers and I think that is the reason it came on. Can anyone help me out?
HELP PLEASE
HELP PLEASE
Not Autozone....CivicTemptress said:Well when it first came on I took it to Autozone and they just told me that it was my 02 censor. What kind of shop do I need to go to? (sorry if i sound stupid but I know nothing when it comes to censors and s**t)
Ok... when you put the header on... did you reset your ECU? If you added the header without resetting the ECU, pull the ECU fuse out for one minute and then replace... then start the car and let it idle for 10 minutes while the ECU get used to the new exhaust system flow rate. If you just add the header without resetting the ECU, it gets confused by the extra exhaust flow, and thinks something's wrong. This has the same effect of what others stated as 'use an OBD2 scanner to clear the code'... this clears the code without needing one of those silly scanners.CivicTemptress said:Yeah I have heard just about everything. So I will more than likely just buy the part and have someone here put it in for me. But thanks for you help,,,
