06 Cluster retro fit into 95 Cvic
ryn004
Has anyone done this?
I'd appreciate it if someone has access t oboth cars to check if dimensionally it's possible. Because I'm not so sure about the height.
Can somone supply me photos of the back of the cluster and wire inputs of the plugs that go into it.
Matt.
you couldn't do that. You would need to swap the whole dash.
oc_civic
i used to think that about EK and S2K so i wouldnt say COULDNT do that.... i mean im sure it would require a TON of modification IF it would work at all.. probably more work than its worth., but just saying who knows ti COULD work? or even more simpe.. look at the teg into ek.. that doesnt really even fit...
ryn004
What I'm planning to do is take a form of the EG Cluster, rip apart the 06 civic cluster and fit them into the form I made from the EG. Like that it should fit into the area nicely.
What Im worried about is that:
- The tachometer of the 06 seems higher then teh eg cluster.
- Wiring would be a nightmare but should be possible, not so sure about the odometer.
