SnakeChamer
145K miles, warranty short block replacement at 95K miles due crack.
Symptom: coolant is being forced out of the system through the reservoir/overflow. Engine compartment gets really hot but engine temp gauge never says above normal. Gurgling can be heard as coolant is exiting the system. No leaks anywhere. Not smoking out the tailpipe. Oil not a milkshake. Both fans functioning. Mechanic thinks it has a failing headgasket causing the cylinder compression to force the coolant out of the system.
Your thoughts/opinion, please.
