12volt ignition
sinisterfuzzy
alrighty, so under my dash is all messed up like chopped wires chillin 'n s**t. and my radio wont turn on. so i was wondering, where is a spot i can just directly wire my deck to get a 12volt ignition or even like a 12volt constant. i looked in my engine bay's fuse box and there was nothing. i was just wondering where i can directly wire this up.
Gogz
Coal Digging Liar Eater
You can take a +12V Switched from your clock ;)
HTH
96sohccivic
get a switch and run a wire from yo battery to the switch from the switch to the steio and its that easy
deadone000
or u just can run a wire straight to the fuse box on the inside
cujo613
Radio 12v white/blue + radio
Radio Ground black - radio
Radio Ignition yellow/red + radio
Radio Illumination red/black + radio
Factory Amp Turn-on
Power Antenna yellow/white + radio
LF Speaker +/- blu/grn - gry/blk radio
RF Speaker +/- red/grn - brn/blk radio
LR Speaker +/- blu/yel - gry/wht radio
RR Speaker +/- red/yel - brn/wht radio
for the acura
and the civic.
Just re build the harness and re attached all the wires and clean it up. Don't bother running new wires, it ends up being a bigger hassle and a safety issue. Just fix em
