i got a 14b a lil while back, but i'm not sure if it's gonna need a rebuild or not (its got a lil shaft play, not too bad though, blades aren't touching the housing or anything, and a couple lil cracks in the exhaust housing but not around the wastegate flapper or anything. definitely nothing big enough to cause boost leak. where can i get a relatively cheap rebuild kit, new seals and all.
also, how do i go about disassembling the turbo? i need to disconnect the compressor housing from the exhaust housing, but i'm afraid i'll do it wrong and f**k up my turbo. do i disconnect the bolts at the end of the turbine shaft, by the blades? or do i just have to unbolt the little belt-lookin thing in between them?
