15X8 +15mm offset, any issues?
Steven.
Formally Green 91
plan on getting some 15X8 with 15mm offset for my 91 crx.
the crx will be lowered, about 1.5-2 inch, plan to run 205/50/15 tires.
might there be any rubbing issues with this set up?
BlackHopeDC5
Is Black Again??? :shock:
yep. Make sure your suspension is real stiff so you can limit whatever bouncing you do on the road cause that will rub for sure
BlackHopeDC5
LongGrain said:
put a lil negative camber on it and you should be fine.
nah i dont think so...
15 offset is really low. modifications are gonna have to be made
ryanM
it isnt that low, i know guys running 15x8 +0 and their tucking with a tiny bit of camber.
BlackHopeDC5
but are they civics.... 0 offest on a civic is all the way out..
maybe so... but i am running 15x7.5 with a 38 offset.. no camber kit
and i am barely making it.. and thats with 195 tires.. stiff springs are the only thing keeping me from rubbing
lilwhitecoupe
Ricer
blackhope your a brave soul running that with stiff springs..... i would go with probbaly like a 40-42 offset if you can..
Steven.
Formally Green 91
i was goign to do 15X8 0 offset, but decided to go with 15x8 with +15(half of stock civic offset btw)
Mr. Lin
Admiral Ackbar
15x8 et15 on a 205?
you should hang with these guys.
BlackHopeDC5
30 is not stock civic offset..i believe 45 is
Genuine Rolla
Its PETEY PETE, y0!
Mr. Lin said:
15x8 et15 on a 205?
:rolf:
o gosh...gotta love the vortex....
but yeah bro..you'll definitly be stretched and poked.
Steven.
Formally Green 91
ok i can get some 215/50/15s to run if i had to
rims i want to run.
those come in 15X8, +15mm offset.
my other option i was thinking.
now those coem in 15X8, 0 offset.
i guess i will have to run option 2, same as above, but with +38mm offset:
they just dont look as good as the ones with the lower offset and only 15x7
Steven.
Formally Green 91
foudn some pics sport max 501s 15X8 +15mm
BlackHopeDC5
that looks sick and stupid at the same time.. Green i think you should get that but somthing with a higher offset. That looks good but its extreme
Steven.
Formally Green 91
if i get 15X8 with teh +35, it changes the entire look of the rim.
ill either roll the fenders or get flares.
that guy is running 195/45s im going with 205/50
and i dont think mine will be that low.
Steven.
Formally Green 91
still shots
the more i look at it, the more i want.
civicwithjdm
how did you put those rims on your car does it rubb because i just bought some axis 15x8 and im not sure if it fits ok do i have to do a flare fender i also have a integra conversion on the back would i have to change it back dose your front rubb i dont know because my car is not dropped yet and havent put it on the car yet too
