kontreeboy
Hi. New user.
I have a 1988 Honda Civic. Fuel Injected. Manual trans. SOHC. NO bells and whistles. Not even a cigerette lighter! About 160k miles. My daughter was driving it the other day when I got a call from her: Stuck on the side of the road. The engine just quit on her. When I arrived, we turned the engine over and it sounds like a POPPING sound thru the exhaust. (Note: The muffler is gone due to rust.) But the popping sound did not sound exactly like a BACKFIRE sound that I would normally associate with an 'out-of-time' engine. However this is the direction that I persued. Removed the valve cover and aligned the cam 'up' marks, and crank, but when I removed the dist. cap, the rotor is IN-BETWEEN the #2 and the #1 'terminal pins'. I would expect the rotor to be sitting dead-on the #1 terminal, but I am not familiar enough with mechanics of this car to know if that is important or not.
I went ahead and put everything back together and then pulled and checked the #1 plug to see that I was getting spark. YES. I also took this oportunity to spray some starting fluid into the #1 cylinder head, reinstall the plug to see if it would 'fire' at least once; but NO. Just the popping sound, which MIGHT possibly be a 'firing' sound... but if it is... it is an extremely LATE one! ??? Any ideas on where to proceed? Oh- one more thing. I pulled the carpet up on the pass. side to see if the little glass inspection window would show me some codes, but it would not blink at all- except once each time the IGN key was turned to ACCY and back off. Thanks for your ideas...
