i had a thread on the car awhile back but plans changed and i decided to go all out and scrap the b20 vtec and go with a full race car build for 2012
chasis
95 ex coupe
gutted interior
dash (heater core blower motor taken out)
all oem wiring taken out of car (mill spec harness, custom 30 wire panel for needed wiring)
CCC racing aluminum drag wing (on order)
omni power drag coilovers
blox lca's
z10 traction bar
cnc staging brake
custom 10 pt roll cage (being fabbed up now)
custom made parachute mount (being fabbed up)
deist pro comp parachute
willwood booster delete
willwood master cyl
exospeed 3 piece front end (on order from cali 2-3 weeks out)
lenso wheels MH 24.5 slicks
lenso skinnys brand new tires
window net from jegs
kirkey seat
head
b16 head cnc flow bench port
sk2 pro 1 cams
ferrea pro valves, springs, retainers
block
Golden Eagle HD sleeves 84 mm
carrillo 1000hp rods w/ carr bolts
cp 9.7:1 pistons upgraded wrist pins
moroso 5 qt pan
complete oem gasket set
oem water/oil pump
trans set up
gsr trans stock gear set
quaife LSD
liberty 5th gear cuff/delete
comp twin disc
dss 5.9 axles w/hubs and ext studs (on order)
turbo setup
pte T4 6766 sp cover (ordering soon)
AFI forward facing manifold
AFI custom made high flow intake manifold
Sk2 73 mm throttle body
turbo smart 44mm waste gate w/dump tube
fuel setup
weldon 2035 fuel pump (-12 inlet, -10 outlet)
weldon A2040 Fuel pressure regulator
(2) weldon inline filters
nrg tech 5 gal. fuel cell (mounts into oem spot)
golden eagle High flow fuel rail
ID2000's (ordering soon)
tuning
p28
hondata s300 (not ordered)
chasis
95 ex coupe
gutted interior
blox lca's
z10 traction bar
cnc staging brake
willwood master cyl
kirkey seat
head
sk2 pro 1 cams
block
moroso 5 qt pan
oem water/oil pump
trans set up
quaife LSD
comp twin disc
turbo setup
fuel setup
tuning
p28
