b20vtak
1995 Honda Civic DX
Made 252 on pump 93.. fixing to switch it over to e85 and shoot for 280.
Engine
Stock sleeve bottom end
Wiseco 14:1+ pistons
Eagle H beams
ARP Main Studs
ACL "race" bearings
Type R oil pump
KMS Block Guard
ARP Head Studs
Cometic .030" 3 layer head gasket
Major Port work done at RP race engines here in town..
Buddy Club spec 5 cams
KMS Valves
Skunk2 valve springs
Skunk2 Retainers
OEM valve stem seals
OEM valve guides
Edelbrock VictorX Intake manifold port matched and extrude honed
Hondata Heat shield
Skunk2 70mm TB
RMF Narrow Replica Header, modified collector to 2.5", with a 2.5 - 3" meg added on
AEM Cam gears
Custom 3" intake w/ velocity stack with "cold air" box
Greddy timing belt
MSD 6A box
Blaster 2 coil
GSR Trans
OBX LSD
3" Exhaust with an Ebay N1 style muffler
hondata s300
Cheapo short shifter
Suspension
Suspension Techniques Front and Rear sway bars
ASR Rear subframe brace
Several energy suspension bushings
Blox rear LCA's
BLox front/rear camber kit
Raceland coilovers
Custom made strut tower bars
Custom made traction bars
Fuel system
RC 320cc injectors
AC Autotechnic Fuel rail
Aeromotive FPR
Aeromotive a1000 Fuel Pump
RCI 8gal fuel cell
Fram pgh1 Racing filter
-8an feed line
-6an return line
All steel braided line
Engine
Eagle H beams
ARP Main Studs
ACL "race" bearings
Type R oil pump
KMS Block Guard
ARP Head Studs
KMS Valves
Skunk2 Retainers
OEM valve guides
Hondata Heat shield
Skunk2 70mm TB
AEM Cam gears
Greddy timing belt
MSD 6A box
Blaster 2 coil
GSR Trans
OBX LSD
hondata s300
Suspension
Blox rear LCA's
Raceland coilovers
Fuel system
RC 320cc injectors
Aeromotive FPR
RCI 8gal fuel cell
-8an feed line
-6an return line
