Well, the .48/.60AR isn't "too small".. It will just spin too fast at the RPMs the motor will spin.
Using that turbo, I made 345hp @ 24psi on my 2.3L 8v Merkur, but it redlined at 6500... And it wasn't efficient at those pressures, I know that. It's "sweet spot" is around 15-18psi..
On a torqueless honda, that turbo will spool quick, due to the .48AR, much earlier than the .63 will.. but on the top end, it'll suffer. (trying not to get technical..
![Razz :P :P](/forum/styles/default/xenforo/smilies/icon_razz.gif)
edit
If you are staying on 15psi, it'll be fine, actually, since the wastegate will keep it from overspooling..
Personally, with my .63AR T3/T04E Turbonetics on my B18C, I don't get boost until about 4500-5000, which in my opinion, is waste.. I'd prefer it hit positive pressure around 35-3800rpm..
