4gauge wire help
Kazan
NYGaleCCo
Hey, I just wanted to know where I could pass my 4 gauge wire that goes from amp to the 12 V battery, a friend of mine told me it's either driver side or passenger side there will be this rubber you just need to rip it and it will make space to pass a wire thruw, he just couldn't tell me exactly where it is, does anyone here know where it is exactly for a 1996 honda civic coupe DX, I think it's USA model cuz when i went to change my muffler pipes he didn't have any in stock and told me your is a USA model, pictures would be really appreciated if possible =)
wfw12
i put mine through a grommet just below the battery on the right. i pulled it out, cut an X and fed the wire through. it came out below the glove box.
there are a bunch of threads about this already and there are pictures, just search
honda98civic
i ran mine through where the A/C drain thing is going through. its right near the bottom right corner of the battery when looking in the engine.
from the floorboard look towards the front where the battery should be and then look a little to the left and it should be a black piece of rubber. stick a knife through it and then run ur wire.
v-tecvillan428
on your car the grommet will be on the passenger side about 1 ft. below the battery pull back you carpet and run it through
