6th gen dies when it is warm outside
nerrag
I have a 98 DX HB that has a problem- The car dies on me when it is warm out (warm being anything above freezing). All winter it has ran fine, it only dies if it is the sun or the temperature is warm. When the car dies, you can get it running again by holding the key in the start postion and slowly letting it go back to "run". Also if you are watching the gauges as they flicker, and it is about to die, if i put pressure on the key towards the start postion, it will not die.
The mods I have done are D16Y8 instake manifold, SRI, stereo system, B&M short shifter.
Any suggestions?
Thanks,
Josh
DetainedCivic
I haz SR20
sounds like you have a short in a wire somewhere. Hopefully it blows a fuse so you know where it is coming from. It sounds like something in the igntion switch. Def. sounds like an electrical problem.
FANATTIC8228
wasn't there a recall a while back for 6th gens due to that they had some kind of ignition problem?
I beleive the ignition was faulty, the car could shut off at any time...
sounds like it's an ignition problem to me...
Matt.
I was thinking something like the radiator. But It might be ignition. Who knows maybe you have no coolant, or maybe you got a block some place.
Jeegz
Did sum1 say mud??
sounds electrical to me. and theres no way it could be caused by a clog in the coolant system. that would only make the car over heat.
99SiTR
Check out the link to the recalls. What do you have the remote wire from you stereo system connected to?
nerrag
Thanks for the link. I am pretty sure that is the problem. i will call the dealer tomorrow and ask them about getting this fixed. Thanks to everyone for replying. As always ClubCivic.com has solved my problem
Thanks
Josh
