87 CRX HF Emergency Flashers not working
CRXagain
I recently acquired an '87 CRX HF that is in generally great (and FACTORY!!) shape, but have found that the emergency flashers do not work when I slide the switch on the steering column to the left. The turn signals all work just fine normally - both front and back, but they stop flashing when the emergency flasher switch is switched on (to the left). Any suggestions???
Todd=)
whtcivic93
www.mm-graphics.net
Im not sure about the older model hondas, but the newer ones with this problem would be fixed by replacing the hazard switch. Yours probably has a relay somewhere being that you said your switch is in the column.
