89 Si transmission swap on 88 Dx
FriendlyED6
Grease Monkey
I have an 1988 Dx model hatchback it has D15b2 motor. I just bought an 89 si transmission. I am wondering what all problems I will run into. I know the 88 is a 21 spline and the 89 Si is a 20 spline as long as I use the clutch for a 89 Si I should be fine ? Right.?. I have done a lot of research and I am not sure if I can use the 88's flywheel. I would rather get it resurfaced instead of having to pay for a new one. As long as I use the starter off the 88 on the 89 Si transmission I should be able to use my 88's flywheel and the 89 Si clutch everything else should be fine? Also does anyone have a link to a step by step picture post of a cable standard transmission clutch replacement?
