92 H22 Hatch checking in
98vtec
This is my DD which I have been slowly fixing. I picked the car up late last year for 1800 with the h22 already swapped in with a built head and wheels but the rest of the car was in pretty bad shape.
The wiring conversion was a fire hazard so I contacted Carlos Zapien and he sent me a tuck harness that was beautifully done. The engine has a EuroR intake which was fudged to work son I contacted my buddy Shawn @ Rosko Racing and had him send me his Euro conversion kit, a set of Rdx injectors and his RDX fuel rail to fix all that.
It had eBay mounts in it which made the car vibrate so bad I could not think straight so I swapped them out for the new has port egh3 mounts. The axles were something slapped together so I replaced them with the DSS swap axles. It was on 212k stock suspension so that had to go. Found a great deal on some tanabe sustec coilovers as well as did the rear disc conversion.
Next up is the rest of the suspension components which are in terrible shape. Skunk2 Pro series upper control arms, Skunk2 rear LCA, Skunk2 rear camber arm, Hard race compliance, front LCA, tie rods, rear trailing arm, rear toe arm bushings have all been ordered to fix the broken and severely worn out bushings and ball joints..
As you can see the paint isn't in great shape with the oxidation but I'm working on getting it shiny again. Just a lot of elbow grease and good detailing compounds.
This is my first time venturing into a civic community as I'm typically on HT (moderator) or other prelude forums so I'm hoping I enjoy this experience.
I'll post some more pictures of the car later.
Thanks
Sent from my DROID BIONIC using Tapatalk 4 Beta
