93 DX auto coupe
SweatDaTeck
i bought a 93 DX auto coupe for 700 bucks thinking i could get it up n running.
now it blows white vapor from the exhaust. I turned it off, checked the spark plugs but no coolant was found.
could it be the head gasket? most likely right?
should i just f-ing scrap the car for parts?
if it were a manual I'd worry about using better parts, but since its an auto i just wanted it back to OEM standards, and use it as a DD.
I think the radiators clogged, the exhaust manifold gasket is leaking.
The guy who had it before threw 17" rims after cutting the springs it looks like, the bottom A frame is bent, i thought i could bend it back.
I like the car because cosmetically speaking its clean.
but every time i fix something something else breaks.
I'm Tired, Frustrated, Deppressed.
I need someone who knows more than me.
Honda Techs help!
after i get off work i'll post pics.
is there anyway to post video of the leaks??
Has the engine overheated?
The bent frame is a big concern.
You should be able to post a YouTube video.
Mysteryemotionz
If the frame is indeed bent it's not worth fixing. I would just part it out. If done right you'll make tore money back and some change. So I would get the France checked out before going Ashby further
Sent from my LG-E970 using Tapatalk 2
