cloudybeaches
Whenever I turn my parking lights on, the #19 kick panel fuse blows. This renders my brake and rear running lights inoperative. If I do not turn the parking/head lights on, I can engage the brakes and the brake lights illuminate. The turn signals operate regardless of the fuse being blown.
The 20A "STOP, HORN" fuse under the hood will also blow, rendering my horn and brakes inoperative.
At first, I could replace the #19 fuse in the kick panel and I wouldn't have an issue w/ the dash/break lights, however that problem seems to have gotten progressively worse where now the #19 fuse will blow the instant my parking/head lights are activated.
The car has had an aftermarket system installed for a couple years, and these electrical issues began manifesting about 2 months ago, so I don't believe that is the issue. There is some damage to the rear-left light assembly, however I've closely examined the wires and did not find evidence of water buildup or anything else I suspected would cause any issue. I also replaced a side marker bulb on the rear-right assembly during troubleshooting steps because it was inoperative.
I have a multi-meter, test light, and other tools at my disposal, I just don't know where/how to use them.
I just want to note that I don't place much value to my troubleshooting skill compared to anybodies knowledge on here and will try anything.
I realize there are other threads with a similar subject, they were not very helpful with my issue.
