Moesef
Hey guys seein if anyone’s come across this problem before.
Car was running good, drove it home after work, did kinda heavy rain, let it sit for about an hour and then I go to start it and nothing.
95 honda d15 swap, no crank, can hear car door beeps, radio sometimes works, cig light plug in works, but when I turn the key to ON or switch headlights on, everything dies.
Try a 2nd time and quiet door beeps, no radio and cig light plug in flickers.
Got new grounds + cleaned connections on all of them including g101, and had battery tested(good) + switched with new one just to see.
Battery clamps are good + newer.
Main relay replaced.
Checked all fuses replaced 80w battery fuse just in case, n replaced a 50w ignition fuse that blew.
Also, fuel pump only worked for 1 key turn each time after I replaced the main relay and the grounds, still no crank both times.
Was thinking a I have a short somewhere but I’m not sure where to start. Lemme know I’m at a dead end right now.
