jenand3
I am new to this forum, so I am hoping I get this right. We recently bought a '95 Civic that runs beautifully, except for when it warms up. The idle sits right at 700 RPM's when cold and then after it warms up and you add any electrical load (headlights, A/C, power brake, etc...) the idle drops to 100 to 200 RPM's and then will stall or the idle seems to start fishing. We have cleaned and then replaced the IACV. It checks out to spec. Also tried adjusting the idle screw and nothing. With the idle screw almost completely out, the idle doesn't go up at all. I know this is not normal, so any suggestions would be greatly appreciated.
Also, as long as the car is driving, there seems to be no problems. You can run any electrical you want and doesn't effect it in the least until you go to stop at a light and then the RPM's drop to 100 and it tries to die.
