95 sedan overheating
HaHaOhWellBro
originally my radiator was overheating because my fan wouldn’t cut on. I replaced the switch, sensor, thermostat, and relay. None of these fixed the fan issue so I wired in a toggle directly to the switch. When I turn on my electronics it will turn my fan on so I know the motor is good. Help. Still overheating. Water pump?
Mr.Baker
Mr. Search
Water pump?
Does any of the following happen?
Are you loosing coolant?
Can you see coolant leaking around the waterpump?
Does the pump rattle or make any noise?
If so, those are signs of a bad water pump.
HaHaOhWellBro
Yes I am leaking coolant but it’s not from the water pump. It makes a rattling sound like it tries to kick on but can’t. Not entirely sure that’s where that noise is coming from tho
Mr.Baker
Mr. Search
Well WHERE is it leaking from, that might be relevant.
A chattering sound could be a bad waterpump.
