95lx=z6
95CivicLx117
So i have a 95 Civic Lx with a d15b7, nothing special at all. It has 191xxx with a rebuilt si trans with new stock clutch. I was wondering if it would be safe to do a z6 mini me swap on it with new seals in the head? Some people have told me i would burn my piston rings up n some said it would be fine. Any suggestions ppl???
James315
kinda high milage but if you have kept up on your maintenance i dont see any reason why you couldnt.
95CivicLx117
i got the car with 148xxx on it n change the oil every 3k n do all the maintenance on it but it does burn a bit of oil but i think its cuz of the valve stem seals letting oil into the cylinder but thats when i get on it a bit. She still pulls strong and am able to squeal tires into 2nd sooo
jordan101
why not just swap a z6 in it instead of putting the z6 head on the b7?
Blood_Shot
have you done a compression check?
if thats good then go for it, its not like youre doing anything serious to it lol
CivicxTree754
z6 head and z6 full motor swap could both take the same amount of time...both are fairly easy. I would do the full motor swap at the least you can rebuild everything off the car until that motor takes a dump.
