Megan_xo
When I bought my car, the drivers power window did not work. My mechanic told me its probably the main switch. Changed that, still nothing. Then I went on and bought a parts car where I was able to take the window motor/regulator out, and switch it. Nothing! I also tested my original motor in my parts car, and go figure, it worked. So I followed to wires to find out that where the wiring harness plugs into the door, all the wires are splitting at the clip. So I went on and wired the whole harness together, using the extra wire from the other car, in other words i made straight wire connection, bypassing the harness plug at the door. After all that, nothing! Checked the fuses, all fine. ANY IDEAS?! Everything else works, except the driver power window...
