He means a jump start. Push the car, put in gear, pop the clutch.
I would say it's one of two things:
A) Your starter relay is bad, which means when you turn your key the relay isn't swtiching over to spark your starter solenoid and turn your starter. This one is the most probably where it sat for a while. Try swapping one of the other relays out with that one and see if it solves anything.
B) Something is wrong with your Neutral safety switch for your clutch pedal. There's a small sensor that sticks out from the fire wall that detects when the clutch pedal is depressed all the way. If that sensor isn't being pushed in, the car won't do anything when you turn the key into the 'Start' position. Try starting the car - in neutral - by getting down on the floor and pressing in the sensor with your hand. It might take 2 people to do it.
Let me know how it works out.
