the_7ucky
New poster here, but a long time user. I've never had to post anything before (I can usually find what I need in some forum), but this time I am at a loss. Like the title says, my car turns over real strong, but it will not crank at all. Before I go into everything I have tried/changed, let me try to set the tone for everyone. I was having some codes thrown (random misfire, cyl 1 misfire, and cyl 2 misfire), and I couldnt diagnose the problem. So I took it to a family friend and shop owner/manager for over 20 yrs (so he is a reputable source), and he told me my dizzy was overheating. Made sense and I drove on it until I could afford the part. It started getting worse (sputtering and CEL flashes), so I broke down and got a new one. I parked the car, swapped it out, and now che refuses to crank. nothing nothing nothing. I've been at it for days tirelessly now and I have no idea where to go next. Now, here is a list of things I have done/replaced since the seemingly fatal incident.
New dizzy, new starter (which was bench tested and jump tested in the car), new plugs, new wires,
I have spark at all four cylinders
I have correct voltage at ignition switch, battery, starter, alternator, ICM,
I have correct resis. at ignitor
I have checked timing multiple times now (mechanical and electrical, which i know elec cant be adjusted)
I have checked for fuel at each cyl., and checked if the rail was re-priming
I have checked all fuses
I have been over every forum i can find and I own a chiltons (which isnt helping as much as the forums usually but it keeps me from running back inside)
One forum said to check the clutch pedal sensor. I do not have one, it was "paper-clip deleted" a long tima ago and wouldve posed an issue before now.
I really tried to keep from having to post ANOTHER thread, but I cant find any forum leading me to another thing to check. I may have missed typing something else I've done, but at this point any suggestions are welcome. I REALLY don't wanna take it to a shop, as I've been pretty good at keeping this car running for almost 10 years now. PLEASE HELP!!!!!
