my passenger side electric window doesnt go down...
when you press the button to make it go up, you hear the motor turn a bit and try push the window up...
but that is only with the passenger switch
the switch on the driver side does nothing at all....
but i connected 2 wires direct to the motor, to see if the motor was done and could only go one way, but the window went down then up.... so im guessin its a loose connection in the wiring... as the fuses are all good!
anyone have ideas?
thanks in advance!
anyone have ideas?
thanks in advance!
