96 EX WINDOW ISSUE,help!
imatuner2
Ok,so my window will roll down,but when i roll it up it wants to go off track or something and the outer guides/seals go on the inside of window.Ive looked and the window seems on track..Any suggestions would be awesome.
JohnS.
BANGARANG
Bent regulator if the track is fine.
crash!
Avi, pull your socks up.
Check the teeth on the regulator. Also inspect the window because the 6th gens came with adhesive ON the window that sticks to the track and over time that dries out. Then it's time for a new window.
My window is currently inoperable for this very reason. It's happened twice and I took my door apart, the regulator is fine, it's the window.
cuetip
mine does the exact samething, i hate it, its a pain n the ass..... most of the time mine doesnt even go all the way up if its cold, but when its warm it will go up just fine
imatuner2
Yea,I had my honda guy check it out and he said its the track and gear thing..sorry if I sound like a noob,but its my 1st honda n had it a week,but have big plans :-)
JohnS.
BANGARANG
Bad window regulator - replace it.
That's what you're referring to imatuner ;).
6th gen power windows are notorious for problems. Good luck!
cuetip
i heard that u can replace the rubber window channel if your regulator is fine... just pull the rubber off and take it to an automotive shop to get a new one, thts what im going to do, when i get new door panels
radracer
last i seen there was a tsb released stating that you losen the guide bar on the regulator and slide it bar 1mm and then do the same on the window mounting bolts and it will fix the problem
