96 LX won't crank. All it does is click.
SeanasarusRex
Okay. I have a 96 LX that is basically all stock except for a remote start. It had about 340k on it before it blew up and put a hole in the block. I bought a new engine for it with 127k. Put in the engine, along with a new manifold. Got it all hooked up, full of fluids and ready to go, and all it did when I tried to start it was click. I could hear the fuel pump engage and all the lights horn etc all worked. Thought it was the starter so I replaced that, same thing happened. Then replaced ignition switch; no change. Read some forums and it said to clean the grounds so i did that; same problem. Oh and I checked all the fuses and they're all good. Pleeeeeease help me. I've dropped almost $2000 in this car and I don't want to give up now.
mymmeryloss
RHD is where its at
Fuel, spark and air.
Figure out which one ur not getting and troubleshoot...
SeanasarusRex
It wont crank or turn over or do anything at all. No way to check that. All I hear is the starter making a click when I turn the key.
mymmeryloss
RHD is where its at
Check the battery. Check fuses. Work your way in from that...
Theres always a way to troubleshoot
SeanasarusRex
All fuses already checked along with the battery. All are good. Battery is basically new and has been charged extensively
JeffBel
Spark? Check your dizzy, wires, and plugs
Fuel? Filter plugged, can you hear the fuel pump when you turn the key to aux
Air? Take your filter off
Sensors? Check all the wires to your sensors around the intake. Make sure nothing is unplugged or severed
SeanasarusRex
Air filter is already off, sensors have been quadruple checked and none are severed, and I can hear the fuel pump. I've literally checked everything over and over again for a few weeks. It won't do anything but click in the starter.
JeffBel
You can try taking the plugs out and putting a little fuel in each cylinder. Clean the plugs while your at it. Oh and check your timing, could have jumped a tooth or two
SeanasarusRex
I don't see how that would help if the engine isn't turning over or cranking or anything at all. Can you explain more?
mymmeryloss
RHD is where its at
Will the engine turn over manually?
mymmeryloss
RHD is where its at
Is your main relay good?
JeffBel
If you hear clicking then the starter is getting power. So that means your not getting air, fuel, spark, or your timing is off
mymmeryloss
RHD is where its at
U said i checked all the electronic stuff. Main relay would be included in this.
And have u actually tested the battery or are u assuming it works cuz u charged it?
SeanasarusRex
Can you tell me where the main relay is exactly so I can double check it again? And I hooked up jumper cables to the battery and tried starting it while jumping it from my brothers SUV so I really don't think it's the battery
THEDARKONE
main realy is but the glove box its a light gray box you shloud here a click when you have it in the second position(:
i sure its that or a battery ha d the same problem were it just clicked and all it was i had some one jump start me up after 10 mins!
THEDARKONE
can you here the fuel pump?
and also i think you just might have to connect your brothers battery stright up
getto way FTW!
MistahJuice
100% real juice
Hey mine does that sometime too. I just made my own wiring connecting the starter wire (the one that slides on no the bolted one) to the firewall where it goes and spliced in a wires for a push to start button so I can test it easily when it happens but I don't get stranded anywhere when i need to use the car. Test the voltage the starter is getting when you turn the key. Mine gets 5-6v when it's acting up so if yours gets about the same were having the exact same problem and I'll keep you updated if I figure it out. Everyone tells me grounds or a short somewhere but I haven't found it yet.
JeffBel
Is the engine the exact same that came out of the car? What are you working with? Block, ecu, obd?
