97 civic coupe cluster
Bennieboiy
this is a dumb question i think
but how do you take off the cluster from a 97 civic coupe
my speedodometer dont work so i think my speed sensor not working i have a ls swap the check engine light turns on and off
everytime i go past 50 mph idk,
never turns on when i drive in town
Kensai
Does the odometer work? The speed sensor is on the transaxle, not on the back of the gauge cluster..
leothelion
d:p
use search on here or google and you will find the answer, but in short, lower your steering wheel to its lowest, take out the two screws holding up the bezel, take out the 4 screws holding in the cluster (one on each corner) and then pull the cluster out and unhook it from the wiring. done.
Pull the CEL code and troubleshoot before assuming the VSS sensor or circuit is the problem.
