97 civic ex...3rd gear problems
blazer92
Hey there, what kind of noise is that and did you noticed where it is coming from?
Hello my 97 civic ex is making a noise sometimes...need help please asap..
Sent from my Z970 using Tapatalk
Come to stop and turn your car off - the noise will be gone. With lack of details I assume the noise you're intermittently hearing is the sound of your engine when it is turned on.
...With lack of details comes lack of support. The more the better!
When does the noise occur? Only 3rd gear? If you push the clutch pedal in does the sound go away? Does this sound happen when the engine is cold? Operating temp? Both? Is it a hum, a whistle, a knock? Does it happen when accelerating? Decelerating? What about when turning?
lethal6
Your Mom's Moderator
Transmission is toast, you killed it.
Sent from my SM-N910T3 using Tapatalk
willost
Main shaft bearing bad. Common problem on the Civic transmission. Especially if you hang your hand on shifter when driving
Sent from my SM-G920P using Tapatalk
