97 Civic front Lower Control Arm blot/Nut issue..
97civicjake
Where the lower control arm bolt goes though and bolts to the nut in side the lower cross member seems to have come lose and moved up to where you can't get the control arm bracket off
I thought about cutting the bolt, but its a really tight spot. Then welding an extension onto the bracket to use the next closest bolt.
Is this is only and best solution with out replacing the cross member?
Any help would be great never had an issue like this with the bolt moving in side the frame and not sure the best way to correct it now as there is no holes in the cross member it self that I can access the nut.
b16lewis
Take a picture
