97 EX Idle Air No Voltage
ugadawg187
When you first start the car you can unplug the iacv with no rpm drop & theres no voltage in the plug. When you reconnect the plug the rpms jump from 1000 to 1500 & the iacv clicks. I disconnected the plug after that & rpms drop & 13.5 volts. Reconnect then press the gas & when it hits around 1700rpm it start sputtering reving up & down. Once you get over 2k rpm it is fine. BRAND NEW IACV btw. WTF is wrong with this thing?! HELP!:roll:
