ncegen
I bought a valve cover gasket replacement kit. In the kit it came with the valve cover gasket, spark plug channel (?) gaskets and new gaskets for the bolts.
Valve cover is back on and I was trying to remove the metal/rubber seals on the bolts and the rubber is too stiff to go over the flare in the bolt.
How in the world do you remove these and install the new ones?
Am I just not man handling them enough? Or is there a trick to doing this?
Any help is very much appreciated.
Thanks
Thanks
