97 honda civic dx with d16y8 swap, really need some great advice on this one!
Kt18777
There is a g101 ground that connects too my thermostat housing and it was loose. It pretty much is the ground for the entire ecu and main relay electrical system etc. it was loose which I wasn't aware till 2 days later after changing thee entire distributor and cap, coil, module, crank/cam sensors, wires, plugs etc. ok I found the ground hooked it back up and my car still is not cranking, nor is there any fire going to the coil to give it spark. So it's something electrical in my car I just don't know what. I checked every fuse, checked timing, changed thee entire distributor and everything inside of it, I do have a bad crankshaft sensor and I'm changing that. My car when I turn it over engine light comes on two or three secs then goes off, main relay clicks, fuel pump is good. I unscrewed the ecu it looks great no burn marks nothing at all! Idk what it is. My car will not read codes when I hook up obd it says error check connection. It's weird I really need some good help
