98 Civic EX with stock 1.6 engine. Changed distributor cap and rotor 2 days ago due to a 303 code I get about once a year and new cap and rotor fixes it. Ran like a champ since. Going down freeway about 75 today and motor just quit. No sputter no nothing just shut off. Had all power still - just no motor. Got to side of freeway, tried to restart, cranks over fine, acted like it was going to catch and run a few times just for a hit or two but never did. Towed it home with truck and tow strap. I thought it was a fuel pump issue due to how it tried to catch a couple times - but now I have it home in quiet garage I can hear the pump running. Shot ether in intake to see if it was a fuel issue - still no start no catch. Pulled #1 plug wire and put screwdriver in it - held next to ground wire and no spark. Pulled #4 wire same thing no spark. Checked PCM fuse it is good. Pulled new dist cap off. The only thing I wonder about with it is I was thinking there was some time ago some kind of spring in there where the coil post is and it is missing. Don't know if that is even a problem or if it has been running fine without it for some time?? The other strange thing was that the coil pin in the dist cap has rubbed on the coil post - not sure if that is a problem or not.
Timing belt only has like 50k miles on it and the motor made no noise like that broke so I'm pretty sure that isn't it. I'm at the end of my "what to look at next" rope. SO if someone can point me in the right direction it would be awesome..
