civickid94
Alright so i'm installing these fogs on my ej7, and everything works except I absolutely cannot get the mounting brackets on. I understand how they are supposed to go on, but they come with phillips head screws, and the bumper, once you cut out the plastic where the fogs go, already has one pre-drilled hole that is far to big for the screw, and the other hole for the other screw isn't even a hole, its more like a line cut in the plastic. Maybe i'm just absolutely retarded, but it shouldn't take 2 hours to try and figure out how to install fogs. So thanks for the help. I tried drilling new holes so that the screws would fit about 1-2cm over from the original holes, but that way the fog won't fit into the bracket...i'm quite irritated actually.
