A-TownSKS
Well this morning on the way to work my car just shut off. Basically as if the battery was taken out, no light no nothing. About a minute or so passed and the lights came back on and I was able to start the car again only for it to die once more several feet later. This continued for a bit to where it would shut off right after it turned on.
A little history, I replaced the alternator and the battery this weekend, and the spark plugs too. The ignition harness was replaced probably a year ago. The check engine light didn't go on beforehand. One thing I noticed that was weird was on Saturday the battery light came on at high RPM's, this is after I replaced the battery and alternator.
Now I haven't read any other threads with this exact problem, but it seems a genuine consensus is to check the 40 and 41 fuse. Is there anything else I should look into? Also I have a manual transmission, I don't believe the clutch switch would cause the car to just shut off like it is.
Thanks a lot in advance guys
