TarHeelBlue
I have a 98 Civic LX that's completely stock I bought last year to use at my part time job delivering pizza.
The car has been dependable and easy to maintain until lately.
I noticed the car missing a bit when I was stopped at a light and it struggled to accelerate. Shortly after this started the CEL came on throwing code P0135. When I pulled the sensor to replace it I noticed the manifold was cracked. Replaced the manifold and cat, put in new 02 sensors and still getting the same code and symptoms. Tested the harness with a multimeter and I'm getting no ground for the O2 sensor heater circuit. Probed the wire behind the connector and nothing. According to the manual the ground is provided by the PCM itself so I replaced it with a good PCM and got the same code and symptoms.
I tried splicing the heater ground wire on another sensor I had and ran it directly to the thermostat housing ground, expecting the sensor to work properly but the check engine light to remain on due to the computer not registering a ground. No results.
At this point I am at my wits end. I have replaced the manifold, cat, 02 sensors and PCM with no change. The only thing I can think to do next is replace the wiring harness from the PCM to the engine and sensors, I am thinking there must be a broken or shorted wire somewhere along the path. I replaced the sensors with Denso sensors that are a fit for this vehicle.
Anyone have any suggestions on this? I have read that fuse #15 under the dash can burn out due to a wiring harness contacting the intake manifold bracket on the bottom of the car and intend to check this out today but I would assume this would provide the power and not the ground.
All of this comes on the heels of our 07 LX going into the shop for an engine replacement after the block cracked. Luckily that one was covered under warranty.
