98' EX Auto to a B18C1
jdmciv
Ride with no name
What up peeps...I have asked a similar question before but I didnt get much feedback. I have a 98' Civic Coupe EX AUTO, if I were to buy a B18C1 motor for it how hard would it be to install (Stick, clutch ped., basically a different transmission).
anekin007
Unregistered User
if you never done a swap before, dont try. let a professional do it.
jdmciv
Ride with no name
I know all about the swaps because I have watched/helped through 2 but is it possible to do a auto to a manual...? I have seen a H22A to a Del Sol and B16A to a 5th gen civic.
silverb18c1
I got a pedal set off a gsr for sale if you need it..50$...
jdmciv
Ride with no name
Where you live/ I'm considering it. Does it include the arms and everything or just the pedals?
anekin007
Unregistered User
i seen a couple of auto to stick swap. the only problem i seen is that the clutch pedel is not set right, it sits really low.
jdmciv
Ride with no name
like deeper back? I kno what you mean, the del Sol I seen was like that. But I dont think it would really bother me.
jdmciv
Ride with no name
would the GSR pedal kit be compatible witht he trans./engine?
HS-POKEY
My suitcase was vibrating
i did a auto to manual swap in my 97 the peddles matched up perfect...no sag from the clutch peddle at all...the reall hard part was gettin the old peddles out and around the steering column...if you have never done it though let a pro do it...the wiring is a pain in the arse...you have to make sure that you wire it to be in park or you will never be able to start it....
