98 ex cel
NowTheWorld
Alright. So this is an issue I've been having since I installed my short ram intake from spectre. It runs great, except I'm throwing a cel since I had to pull out the intake sensor. Any way to permanently disable that from coming on, so when something else trips it I'll at least know about it? Also, I'm only getting 260-270 miles a tank. That's highway miles w cruise on. City I only get about 220 miles. Any way to fix? Thanx
Is the IAT sensor unplugged? If so, why?
And why would you want to disable the ECU? You want it to alert you to any sensor problems.
Pull the CEL codes and post them. Then reset the ECU to see whether any codes return. If so, also post the codes that return.
NowTheWorld
Iat is unplugged because the new intake didn't have a place for it. I also guess I misdirected you. I want to clear this code for good so if anything else breaks I know about it
codeman76
Spectre has a kit that comes with the proper size hole saw and a assortment or rubber grommets So you can install you IAT sensor in the intake tubing. I think its is a special order at orileys and autozone though. Spectre part # 8711
NowTheWorld
Thanks a lot! Gonna get another sensor and that part next payday. Any word on why my mileage is so crappy? Lol
JohnS.
BANGARANG
Just drill a hole in the intake, install a rubber grommet, plug in the IAT and be done with it.
Like Ron said, reset the ECU (once the IAT is plugged in).
The ECU requires signals from the IAT sensor to maximize gas mileage and engine performance. Properly install the IAT sensor and go from there.
Why did you throw away the original IAT sensor?
NowTheWorld
I forgot to take it out of the stock air box and I didn't realize it until I couldn't find it. Anyway thanks ill get that fixed on the 1st
emerican
Yes that is your problem if you dont want to buy a new intake drill a hole in the current one and use a groment and put the sensor back in there.
Or you can order the intake that already has the spot for it.
