98 honda ballade cranks but wont start
Azizo
Hey guys .....new member here an in dire need of help.My car was working fine until i tried to start it the next day...i switch ignition on,engine light goes on ,main relay clicks ,fuel pump primes,it cranks but wont start.I then turn ignition off an main relay clicks again.I then had a friend check if i have fuel coming thru an if i hard spark...an both are there,ive read forums but cant find a solution an dont wanna spend tons of money on things that are working fine...i did nothing to the car as it is a great runner just this happened out of the blue.tx
RichardCrainium
you need fuel air and spark in a civic one is missing. Make sure you have spark on all plugs and check to see if you have fuel at the motor. If you have that check your compression and make sure all cyl. are correct.
