Remove the screws on the backside of the power locks from the door handle cover piece.
Remove the door handle cover piece off the door handle.
Remove the screw on the inside of the armrest pocket.
Take armrest pocket out.
Unplug the window control switch.
Pry the piece on the inside of the side view mirror out. You may need to pull the door panel out next to this piece so the clip comes out to get it free.
Remove the 3 screws that hold the speaker in.
Remove the 3 screws around the speaker that hold the door panel in.
Go around the sides and bottom of the door panel and pull out to pop the clips out.
Pull upwards on the door panel and it should pop right out.
