From Honda Tech
1. 93-97 delsol or 94-01 integra or 99-00 Si or "some" 92-95 Civic Si
trailing arm assembly.
2. delsol/Si rear
brake lines (if you use integra trailing arms/calipers you need INTEGRA brake lines...they have a COMPLETELY different caliper attachment that WILL NOT work with delsol/si calipers).
3. 99-00 Si Emergency brake lines (integra lines will work but they come together into a single rubber floorpan grommet which you'll have to hack up and you could hear wind noise, etc under the carpet).
4. 99-00 Si Master cylinder/
proportioning valve (you can go with integra parts but you'll have to flare lines, etc) the Si stuff is drop in.
I understand all this but my main question is will my current coilovers, rear camber kit, lower control arms, and adjustable tie rods fit if I do this swap? Also, am I right to assume emergency brake lines is a different way of saying parking brake lines?
