slammed98ex
Here's my issue that I am trying to solve. My car will be driving fine with no issues and when it warms up the engine just shuts off and loses power. There are no check engine lights that come on or anything. I checked today and when this happens the car is losing spark and takes 5-20 minutes for the car to be able to be started again. To this point I've changed distributor, coolant temp sensor, plugs, wires, battery terminals, main relay, ecu, and intake air temp sensor. I know the fuel pump is turning on as I can here it prime. I haven't done the ignition switch swap out as these cars are known for them to go bad but the person who owned the car prior to me did. I'm literally at a loss. I checked grounds and sanded them down to make better contact points. Is there anything that I seem to be missing or has anyone else had this problem before? I do know the car had a wreck prior to me buying the car and was hit pretty good in the passenger door and fender area. Any help will be greatly appreciated as I can't think of what else to check besides maybe the harness.
