99 civic sedan driver door actuator problem
Kali Hissle
SICKSPEED
I installed the actuator and it works plus I got a new remote and programmed it and that works.so all my doors lock and unlock except the driver door I still need the key do lock it or unlock.so by the new actuator being installed and working could the harness it plugs into be causing it not to lock and unlock the driver door.
JohnS.
BANGARANG
Sorry but I barely understood your post. So you bought new actuators but the driver side still doesn't unlock with the remote? If the key works, it is possible that you either got a bad actuator or the harness itself has problems.
Kali Hissle
SICKSPEED
Ok thanks im gonna go with the harness because when I unbolt the actuator and move the switch I hear the other doors unlock or lock so there must be a shortage in the harness.
Kali Hissle
SICKSPEED
fixed it it was the wires rotted near the boit on the door.
Sent from my SGH-T679 using Tapatalk 2
