could do it on an alignment rack, ive always just tightened them though since i cant get on a rack and im not to worried about it lolHow do you torque a bolt when your car is under load and low to the ground. I don't see how you would be able to get yourself underneath the car. Just thought I'd ask something ice been thinking about.
hahaha wow now thats an answercould do it on an alignment rack, ive always just tightened them though since i cant get on a rack and im not to worried about it lol
The car doesn't have to be on the ground, it could be on ramps. Or jacked up and placed of blocks of wood. Or you could take measurements, place the car on jack stands and jack the wheel up to load the suspension then tq. However it's done, loading the suspension to its normal static state and torquing to spec is the right way to do it.How do you torque a bolt when your car is under load and low to the ground. I don't see how you would be able to get yourself underneath the car. Just thought I'd ask something ice been thinking about.
Ok thanks I was able to torque my was setup because the car wasn't lowered and I'm small enough to fit under the car but next time around I might run into issues unless I raise the coils high enough to get under there then lower the car afterwards.The car doesn't have to be on the ground, it could be on ramps. Or jacked up and placed of blocks of wood. Or you could take measurements, place the car on jack stands and jack the wheel up to load the suspension then tq. However it's done, loading the suspension to its normal static state and torquing to spec is the right way to do it.
